When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Send it back to Casio for a free estimate.
Depending on the price of your camera you can decide if you want it repaired. The price they charge is reasonable only problem they only give a 3 month guarantee.
Try turning off the camera. While it's off remove and reinsert the memory card. If the same message appears, you should re-format the memory card. CAUTION: Formatting the memory card will delete anything on it. Copy the files off of it before formatting.
Here is your manual: http://support.casio.com/pdf/001/EXZ60_e.pdf
There's a little door at the top part of your phone which faces you. Open that door and you will see a series of buttons with a label for each one, including one for setting the greeting. Also, on the inside of that door itself is an explanation of how to set a greeting. As for erasing messages, look at the front of your phone, with that same little door closed. now look at the top row of buttons, the second button over is the erase/save button. Pressing down the left side of the erase/save button will erase your messages. Pressing down the right side of that button will save them.
Contact : Amar Mobile : 9876101234 [Send Free SMS]
Enter Your Message. [Max Limit 100]
Your Name
Your 10 Digit Mobile No.
Enter Verification Code 0e4e5f Phone : 9811137536 Address : 2879 Sant Nagar Main Road Rani Bagh Near M2K Pitampura New Delhi website :http://www.beyondlaptops.com
Your Name
Enter Verification Code 3bef54 Phone : 9811137536 Address : 2879 Sant Nagar Main Road Rani Bagh Near M2K Pitampura New Delhi website :http://www.beyondlaptops.om
