For natural gas, bench top 4 burner hot plate push and turn so ignite knobs and leads to burners
Yes,its true
This is a magnificent control board
We bought Piezo in the mall, in a regular store, I can not remember the name. The control board is very satisfied. But together with the stove decided to change the kitchen, choose here at furniture store https://nyfurnitureoutlets.com/, the prices are not high, and everyone does very professionally . The new kitchen and stove looked excellent.
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
If you hear clicking or sparking, go to Step 2.
If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
Check to see if the burner works, If not, then go to Step 3.
Check to see if the burner works, If not, then go to Step 4.
SOURCE: One of the gas burners does not open.
The valve is either clogged or defective. Best bet is to get a new valve. Servicing old ones is a poor bet. If you are unsure how to install it, get a service person. Gas can be dangerous if the job is done wrong.
SOURCE: 2 of 4 burners ignite, all tick?
The two front burners are used most often. On the side of the burners are tiny holes that become plugged and keep the burner from lighting. If all the burners are the same size try swapping the heads around. If they are not all the same size be sure they are in the correct position and fully seated on the top. Sometimes the heads have to be replaced when cleaning no longer works.
SOURCE: I cleaned my stovetop (gas with 4 burners). Now
It works now.After two days of trying, it now works like it should. I'm thinking something needed to dry.
SOURCE: Water spilled into the controls of my GE range top
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
What is the complete model number of your unit?
