Have a ONN clock radio model ONA15AV101 - how do I set the clock
THE UNIT TO POWER
Plug AC power cord to the AC wall outlet. Before switching on the unit, make sure that the voltage of your
electricity supply is the same as that indicated on the rating plate.
BATTERY BACKUP
Insert 2 AAA batteries into the battery compartment. Be sure to observe the proper polarity (the "+" and
"-" signs) as indicated inside the battery compartment.
In case of power failure or interrupted AC power, the current time, alarm time settings, and stored radio
stations are preserved in the memory of the unit using the battery back-up function.
SETTING THE CLOCK
1. With the unit in CLOCK mode, press and hold the CLK/MEM button for about 1 second, the time will
begin to flash on the LED display.
2. Press the ?/HR button to adjust the hour.
3. Press the ?/MIN button to adjust the minute.
4. When the correct time is selected, press the CLK/MEM button again to confirm.
SETTING THE ALARMS
1. With the unit in CLOCK mode, press and hold the ALM1/VOL+ or ALM2/VOL? button. The ALARM
time will begin to flash on the LED display.
2. Press the ?/HR button to adjust the alarm hour.
3. Press the ?/MIN button to adjust the alarm minute.
4. When the correct time is selected, press the ALM1/VOL+ or ALM2/VOL? button to confirm.
5. Press the ALM1/VOL+ or ALM2/VOL? button to select the ALARM sound mode - buzzer or currently
set radio station. The alarm buzzer or radio indicator will light up.
SNOOZE FUNCTION
1. Whenever the alarm (radio or buzzer) activates, it can be temporarily suspended for a short period of 9
minutes by pressing the SNOOZE/SLEEP button once.
2. The buzzer or radio will then automatically activate again after the 9 minutes SNOOZE period has
ended.
3. This procedure can be repeated for up to approximately one hour.
DIMMER FUNCTION
Press the DIMMER button to change the brightness of the display.
TURN OFF THE ALARM
When the ALARM activates, press the ALM OFF/SOURCE button to turn off the ALARM.
LISTENING TO THE AM/FM RADIO
1. Press the ALM OFF/SOURCE button to select the FM or AM mode.
2. Press the ?/MIN button or ?/HR button step by step to tune to the desired radio stations.
3. Press and hold the ?/MIN button or ?/HR buttons for approx. 1 second, it will start to search the
next radio station in the direction of the search. The search operation simply finds stations with
