SOURCE: dual-xd7500
you can buy the plug from the company.it like $30.00 plus shipping their number is 1-866-626-7863
SOURCE: Need a new wiring harness for my Dual XDMR7710
Look in your local phone book yellow pages under stereos for a local (not big name) stereo installation store (there will be one) and go there.....you will thank me!
jack
SOURCE: Need Pinout
no - the harness is $17 or less.
Even Metra makes one (pictired above)
In my shop I charge $17 for the metra plug.
eBay it.
Metra part# AL16-0001 or al2x8-0001
CLICK HERE for an eBay auction for an original ALPINE plug. $30
CLICK HERE for an eBay auction for a $2 (shipped) one.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
SOURCE: I need the factory wire diagram for 1997 Ford F150 radio
go here shows you all about it http://www.installdr.com/InstallDocs/FLM/PDF/356007.pdf
SOURCE: 04 toyoya camry radio wireing harness pin
Hi there: Car Radio Battery Constant 12v+ Wire: Blue/Yellow Tehy could be harnesses 15 or 20 pins, try to look your right replacement in this links: - 2004 Toyota Camry Stereo Wiring Harness - 1990-2013 Toyota Camry Auxiliary Car Audio Input Adapter Kit Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
According with the diagram on 2004 Toyota Camry Car Radio Wiring Diagram...
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Thank you for using FixYa, have a nice day.
