SOURCE: I have a TP-LINK router and atp-link usb cnection
Thank you very much for all your trouble.
I have changed the setting in the Router from password to passphrase,rebooted the router and bingo it works.
Kind regard
Jai
SOURCE: Sound & e management tools not working. web download difficult.
uninstall your sound driver and reinstall again
if you download from wed please conform *********** board serial number then after you down lode a capable driver for your motherboard and then install it.
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
SOURCE: TP Link Nano 702
An address that starts with 192.169 is not a private address. It should start with 10.x.x.x or 172.16.x.x or in your case it should start with 192.168.x.x
