Question about Razor Health & Beauty
2 new batteries, but when I twist the throttle there's a "click" in the lil square box next to the batteries. Not sure what it's called. Is there a simple fix?
It's a E175 Razor
Locationoffuelpumprelay
it is under the hood in the fuse box/panel top of panel says location itll be a lil blak square to test get another relay lil black square from the fan or somewhere else and switch em if anything changes its badd n needs replaced if not off to other things.
Mar 18, 2015 | Cars & Trucks
Throttle positing senser on a 99ranger I changed it now the idle is way to high
The positioning of the new TPS IS OFFSET....It is possible to install it wrong by accident..I have seen this happen before..The pressure from the sensor plastic actuator has been installed and slightly twisted against the throttle lever inside which causes throttle to raise slightly....Wear safety glasses and disconnect battery..Remove sensor slowly and carefully while removing and watch the throttle lever inside to see if it moves in any direction...Carefully install it again making sure it doesn't twist the throttle lever inside where sensor mounts...The lever on the sensor should stay in its position...Carefully install sensor making sure it doesn't twist...Connect wiring and battery and start for a safety check.....It is possible to have a wrong sensor or faulty new sensor...Double check that it is the correct sensor...
Mar 01, 2015 | Cars & Trucks
Husky 224L is new, starts easy but when i start throttling, the string trimmer barely spins.
This machine has a flexi drive shaft ( like a big speedo cable ) there are a number of things to check, make sure the gearbox is pushed fully onto the tube, slacken the pinch screws and twist and push the gearbox fully on, check the tube is fully into the engine housing, slacken the pinch screws and push the tube fully in, failing this the flexi drive may damaged, remove the gear box, pull the flexi drive out and check the condition of the square ends.
Jul 10, 2011 | Husqvarna Garden
My new discover 150 bike ,is not getting starting at morning .after somuch of effort only its getting sterted why like this happens
Chances are you are flooding the engine when trying to start it. Twist the throttle once then kick over four or five times. If it doesn't start, then twist the throttle one more time and kick again. Be sure the battery is charged up and the air cleaner is clean. Install a new spark plug.
Mar 14, 2011 | Bajaj Discover Motorcycles
Poor starter, plug gets wet, starts when bumstarted
First, get a fresh sparkplug. Next, charge the battery. Batteries usually only last two years or less. A battery that will not hold a charge will rob electricity needed for spark. On a bump start, the flywheel generates more electricity than a kick start. Give the throttle only one twist on your morning start if your bike has a power valve. The valve gives a shot of gas when the throttle is turned. Twist too much and the engine will flood. Please rate my answer. Thanks.
Aug 23, 2010 | 2000 Sym Husky 125
It will not turn on any longer
the problem lies within the mp3 all you got to do is fisrt.becarefull and take it apart once you have the other layer taken off then take the back off then at te top where the power button was there should be a lil square take something small and push in the lil square and it should come on the reason it wont cut on any more is due to the power button. the lil hole at the end of it is missing the part that normally pushes inside the square button is missing you will have to figure something from there to turn it on.i had to rig mines and your welcome.for further information you can call me at 771-3337
yours truly C.3.C
May 19, 2009 | SanDisk Sansa Clip MP3 Player
I need a schematic for the x-treme scooter
Check the batteries, they need at least 12+volts to run scooter. Blinker may be burned out or the wire came loose. If batteries are charged Two things That could be wrong are: Twist throttle is NO Good, Or the controller is BAD. You need a voltage tester, (Disconnect the Wiring Harnesses) and check voltages coming out of the controller(the silver BOX with lots of wires) and see if it is sending voltage to the twist throttle. Controller wires to the Twist throttle should read 4-5 volts.
(Make Sure You Unplugged That Wiring Harness) There is 4-6 wires in that Wiring Harness then find + and - test them for voltage from that Controller box wiring harness. If You get a positive reading out of that Controller wiring harness then the Twist Throttle thing is bad. If you get NO READING out of that Controller Wiring Harness Then if is BAD. Normally it will be the dead batteries or the Twist Throttle that go bad. Batteries are expensive, Twist Throttle Cheap. Good LUCK
Apr 03, 2009 | Electric X Treme X 360 Scooter
Where is my fuel filter located on my 2003 alero
check battery cables .make sure they are clean and tight .check battery volts. it should be 12.5 volts. your fuel filter is above the gas tank right next to black square plastic box . call the charcoal canister.
Mar 16, 2009 | 2003 Oldsmobile Alero
Green light in square box with #1 written in it, right of F12
make sure this keyboard is compatible with the new system.
I would check especially if your system is vista.I'm sure it was setup to use the new keyboard
do you have software for the old keyboard
Dec 10, 2008 | Logitech 967437-0403 Keyboard
Health & Beauty Logo
51 people viewed this question
Top Razor Health & Beauty Experts
Tom Chichester
Are you a Razor Health and Beauty Expert? Answer questions, earn points and help others
