SOURCE: My sewing machine is not sewing stitches
That is irritating! Singer has your manual; check out: http://www.singerco.com/accessories/manuals.html
I believe it costs $15.00.
Happy sewing!
Robbie
SOURCE: When i start to sew
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
SOURCE: lost my sewing instruction manual when moving
Hi
You can download some partial manuals from the Janome site.
This is for the Janome D'cor Excel Pro 5124:
http://content.janome.com/documents/File/ManualFile/DecorExcelPro5124.pdf
Which should be similar to the ohter model number you mention.
Hope this helps!
have you checked to see if the bobbin is in the bobbin case correctly
is it still under warrenty? you might want to take back to the place you bought it from & let them check it
SOURCE: janome machine probs
try a ballpoint or a stretch stitch needle, that what I use when sewing
knit, t-shirt. it doesn't break the fiber in the fabric.
