Please tell us more. Is the top thread not catching the bobbin thread? Are you getting a malformed stitch? What???
Testimonial: "The thread does not even go into the fabric."
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning
with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test
it to make sure the tension is working correctly.
(To do this
test,adjust your tension setting to normal or medium or 5 or something
in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the
thread. It should pull noticeably harder.) If it passes this test,
continue up through the take up lever,then down through the thread
guides to the needle. Make sure your needle is fully inserted and
turned the correct way.( If you load your bobbin case from the left
side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are
some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
SOURCE: Kenmore 158.1703 sewing machine - needle not going up and down
The machine sounds like it has threads caught in the bobbin area thus locking the machine up. Check in there and maybe you can pick them out with tweezers. They may need to be 'softened up' with a little oil before you can get them out!.
also Please push the bobbin winder back to the left position and it will release the bobbin winder. Then you should be able to sew. If the needle won't move, you will need to tighten the turning wheel on the right side end of the machine. This should move your needle. Then you should be set to sew.
------This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
