SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
SOURCE: i want to know how
I have a Timex Men's Classic Digital Silver-Tone Expansion Band Watch #T78587. To turn the chime on and off on this watch, I press the Start/Stop button on the top right once. This toggles the chime on and off. If you hear a single beep then you have turned it on. If you hear no beep you have turned it off. You can tell the chime setting by looking at the colon seperator between the hours and minutes. If it is flashing then the chime is on and if it is not flashing then the chime is off. This is not explained in my watch manual nor in any of the manuals I downloaded from Timex.com.
SOURCE: Timex IndiGlo Ironman Triathlon - bell stopped working
You have lost the coilspring wich connects the watch mechanics with the speaker integrated in watch caseback. This is why you do not hear any sound but still can see the icon.
Check the area where you made the battery replacement very carefully- you may find that tiny spring. Use the magnet if necessary.
If you can not find it, go to the nearest watchmakers shop and ask to supply the new coilspring.
Do not forget to rate, please.
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
SOURCE: Timex Sleek stopped beeping when I replaced the battery
I had this problem. I simply flipped the metal plate on the back 180 degrees.
I noticed on the inside of the metal plate a pad about the size of the battery, and guessed from the other notes that this must perform some kind of insulating function. Furthermore, the writing on the outside of the metal plate was not oriented "up"... that is if I was holding the watch in front of me like I was reading it, the writing on the back plate was upside down. Both of these clues led me to believe that the plate had been re-installed wrong. Flipping it around fixed (restored) the beep.
