Question about The Health & Beauty
I have a used mx650 that I pulled from the trash. I replaced the speed control and throttle. Also the batteries and the charger. The charger says full charge but the throttle says low charge and it just clicks when I turn the throttle. Motor is only thing I haven't replaced. Please help!
    Top Expert:
  • The Master
  • 84,619 Answers
Have the batteries load tested, I bet they have dead cells.
Posted on Jul 14, 2018
  • Randy rohrbach Jul 14, 2018
    I just bought the batteries "brand new". So I haven't load tested them but I'll have to give that a shot. Any other possibilities with it being the motor? I get no movement from the motor at all.
  • Marvin
    Marvin Jul 14, 2018
    Pull the motor test.
SOURCE:
dgjtex
  • 405 Answers
SOURCE: 2006 dodge ram diesel won't turn over to start
Sir I can help you with this, I have all the service manuals on your truck and will provide anything you need, but this honestly sounds like a bad wire connection or ground on a primary battery cable. I would trace all my battery cables and clean every connection even the engine ground cable and the one at your starter. I will be glad to help you further, I can post step by step trouble shooting guides on your truck if you need them. Hope this helps.
Posted on Dec 29, 2008
  • 32 Answers
SOURCE: battery charger on board doesn't work. Replaced everything, stil
try replacing the battery fuse
Posted on Jul 13, 2009
  • 103 Answers
SOURCE: Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
Posted on Nov 10, 2009
  • 10 Answers
SOURCE: I lost the instructions to my wii battery charger.
There's probably some light on the charger that would either change color or go off when the battery's charged. And it's usually okay to leave the Wiimotes on the charger when not using them, but I wouldn't leave it on there for super long amounts of time if you're not going to be using it foe a while.
Posted on Nov 26, 2009
2strokeJim
  • 577 Answers
SOURCE: stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
check your muffler screen for being plugged, this will cause it to not accelerate
2StrokeJim
Posted on Nov 19, 2011
We had the batteries replaced on 3/30/16 and now the red light is constant and when we charge it .. nothing changes... it barely moves and I do not believe it charges... the batteries are new
They have complicated control computers and are very touchy concerning the amount of voltage in various parts of the system, such as how much current the motor is drawing. Sometimes transmissions go dry of oil causing the gears to bind, throttles develop oxidation on the contacts, terminals get corroded. I had to bypass my original unreliable controller completely with a DC variable speed board from China. Test your batteries by connecting each to their own standard car charger. Get the back wheels off the ground with blocks and test run the motor while connected to the chargers. And test each battery with something powerful that can determine its strength, not just a small test light.
The chargers are reliable, but the control brain (module) maybe not. Make sure your batteries are not dry, make sure fuse is OK, terminals are clean, charging system must be unplugged to run, test test test. Make sure the speed limiter is tried in various positions, parking brake or lock is in correct position.
May 13, 2016 | Pride Jazzy 1103 Ultra Standard Power...
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
What is wrong when full power on throttle but only clicks
Check the battery voltage right after the charger shuts off. Should be around 13 volts on each one. Short the power switch contacts and if that helps replace it. Check that the motor and wheel turn freely and dont make noise. Check all the contoller connectors. Sometimes they melt and the connection isnt good. You can always connect the batteries directly to the motor and if it goes full speed then you need what razor calls an electrical kit which has a throttle and controller.
Jul 23, 2014 | Razor MX500 Dirt Rocket
I have a IMC Heartway Gypsy and the power light blinks 5 times and the scooter won't run. I have just replaced the batteries. Is there list of what each code means? Thanks
1. Battery low
2. Battery charge is too low
3. Battery voltage too high or charger still connected
4. Current limit. turn scooter off for a few minutes and then on
5. Brake lever in freewheel mode
6. Throttle lever not in centre on switch on or faulty
7. Speed pot or throttle pot error
8. Motor volts error
9. Other internal fault/control fault
Hope that helps you.
May 18, 2014 | Pride Mobility Products Go Go Ultra X 3...
Low power
Yes, your batteries need replacement, that will solve the problem.
Mar 19, 2013 | Razor MX650 Electric DirtBike
My pride go go elite traveler 4 wheel stops randomly often with no beeps. I have replaced the throttle, the speed pot, the brake, and the batteries check out fine.
You may have a loose connection at one of the harnesses or connectors. If there are no codes you may have a bad controller or loose connection at the controller. Slow speed problems may be motor or motor brush problems you can diagnose by visual inspection or a voltmeter. Load test the new batteries and the charger output. Block it up and run it checking and knocking all the components until it quits. I have seen a dragging brake caused by a melted controller harness at the controller connector cause a similar problem. Hope this helps.
Aug 18, 2012 | Pride Go Go Elite Traveller Plus HD 4...
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
I have a gogo scooter it bleeps once than cuts out I have to turn it off and back on for it to move
probably a dead battery or a bad battery will move you till the controller gets to a threshold voltage then it beeps and stops , testing this is easy turn on the scooter adjust the speed control to the lowest setting then start riding the scooter at full throttle then start turning up the speed controller if that produces the problem then the batteries need charged or replaced
Jul 01, 2010 | Pride Mobility Products Go-Go Elite...
Battery shows 24.8 volts no power
Yes, your batteries are trashed. You need to replace them. Or take them off the chair and put them on a car charger,slow charge. They need to be up over 24VDC. If they fall under 24VDC the charger won`t recognize them and won`t charge.
Mar 30, 2009 | Golden Technologies Buzz Around 3 Wheel...
Health & Beauty Logo
50 people viewed this question
Top The Health & Beauty Experts
D. E. Hev
poizniv
poizniv
Level 1 Expert
OHare
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
