I have posted the page in the service manual for this issue. It is not something that a person with no electronics experience can fix. It requires product knowledge of integrated circuits and use of electronic meters and the ability to solder. https://www.manualslib.com/manual/768347/Panasonic-Sa-Akx74lm-K.html?page=29
SOURCE: F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
SOURCE: panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
SOURCE: How to fix F61 error?
First re solder any dry joints on Transistors Q502, 504, 507, 515 & CN500, IC501. If there are no dry joins replace IC501 (STK470-0??) & maybe D501 (16.V) zener
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
