I recently acquired the piano with a stuck key. I want to fix the problem myself.
First determine what the material of your digital piano keys are. Many digital pianos now days have plastic keys but if you have those ebony black and ivory white keys, you need to clean them with extensive care.
1 - Use a damp cloth for cleaning your keys and make them dry.
2 - Use a small amount of liquid soap with a damp cloth.
3 - Clean dirty keys with this cloth. Your grip must be firm but rubbing must be light.
4 - Gently rub keys until they are completely clean.
NB: These steps can be followed for plastic keys but for ivory keys, you would need to get ivory scrapper
SOURCE: Yamaha digital piano clp 170
This is a common problem with Yamaha keyboards. The problem is caused by worn-out rubber contacts in the keyboard assembly. In my old Clavinova CLP-500, there was one long rubber contact strip under the keys with two parallel strips of semiconductor material. The Clavinova circuitry determines key velocity by measuring the timing between when the key hits the first and second strips of semiconductor material. The harder you play a key, the less time it takes the key to hit the second semiconductor strip after hitting the first.
After years of playing the keyboard, the keys eventually cause tears in the semiconductor material and this messes up the timing measurement for key velocity. The only solution is to take the keyboard apart and replace the rubber contact strip with a new one.
I got rid of my CLP-500 four or five years ago and got a new CLP-170. The CLP-170 is now having exactly the same problem that the CLP-500 had. Yamaha has re-designed the rubber contacts in the CLP-170 so that there are now eight individual contact strips instead of one long one. The problem is essentially the same, though. You have to take the keyboard apart and replace the worn out rubber contacts.
Here are the part numbers for the rubber contacts that need to be replaced in the CLP-170:
V8286600 Rubber Contact, 12 keys, D-C# Qty. 6
V8286800 Rubber Contact, 11 keys, A-C# Qty. 1
V8286700 Rubber Contact, 5 keys, D-C Qty. 1
I suggest you also get a copy of the CLP-170 service manual, part number 001677. It has descriptions of all the steps necessary to take the thing apart and put it back together again. You'll also need a "rod" (which is just a long dowel), part number TX000670. Before you take the circuit boards off the keyboard assembly, you have to insert the dowel between the keys and the frame to keep the keys from falling back and getting in your way. A 5-foot long 1/4-inch dowel will probably work. (I haven't yet taken apart my CLP-170, and I don't have Yamaha's "rod," so I'm not sure if 1/4 inch is the right size or not. I'll report back here if it's not.)
Good luck,
Howard
SOURCE: Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
SOURCE: roland hp550g digital piano has a couple of dropped keys
Power off the unit. Disconnect all cables that plug into the speaker base if you have one - It may be wise to document the individual wires to make their reinstallation easier. Remove the unit from the speaker stand and lay it on the floor on something like an old towel - you may get some dark colored grease on the rug. Remove the screws only for the bottom rear, not the front - you don't need to remove them. Do this by gently turning the unit upside down. Only remove the screws from the sides/rear bottom, and note which screw types you removed from where. Once all bottom rear screws are removed gently return the unit right side up. now pivot the top rear cover - the sides of the cover are attached to the rear - pivot it toward the back. No need to remove the ribbon cables - just let the top lay there or prop it up with something if the ribbon cables don't have enough slack for the top cover to lay flat on its back. You should now be looking at all of the keys uncovered. notice the rear of each key is where it hinges. You'll notice the grease at the hinge point. The keys are thin plastic so you must take care not to damage them. The way to remove a key is to spread the ears at the hinge point of the key you want to remove. I use a screwdriver sharpened to a point, but a large pair of needle nose pliers work good too. You insert the tapered point of the tool between the ears gently to spread them far enough to just clear the pins. Once they are spread wide enough you'll feel them disengage. Each key also has two hooks located side by side towards the front of the key on the bottom side - they are not visable until the hinge is released, but you must realise they are there or you'll either snap the key back onto the hinge or not be able to pull the key out once you've got it off the hinge. Pivot the key towards you to remove it. What you now have in your hand is not the defective part. You have the top that is touched when playing the keyboard. The defective part is still setting in the mechanism. What's actually happened is the keys are made of very thin plastic where they are glued around the weight and this plastic breaks leaving the weighted end down there somewhere. Examine where the key top came from and how it works. The key top is the part you took off of the hinge. You can see how the keys on each side work and you'll also see what is missing from the mechanism for the key you're working on. To make things easier I always remove one additional key top on each side of a key that I repair to make access easier. Just place the other keys you remove right behind the key area in the order you took them off so it'll be obvious how they go back on. Now the broken weighted mechanism you can lift right out. Actually you can lift it out easier with the weighted end broken off, but once you glue it back together you can still get it in there without to much trouble. You only need to remove the damaged weighted mechanism for the key you're repairing. I remove the key tops on each side of the damaged key for visability only. Take your pair of needle nose pliers and pick out the broken end. Now fit it onto the end of the weighted mechanism in preparation for glueing - just so you can see how it's going to go on there. I use a high quality modeling super glue. Before I came across this glue I used JB Weld, but it takes a few hours to dry. The high quality super glue allows you to put everything back together immediately. Installation is reverse of removal: Snake the weighted mechanism back in once you've repaired it - you can always examine those on each side if you get confused. Hook the key top front first then smoothly snap in place the hinge ears over the pins. Make sure to check the movement of the repaired key, and check also to see if anymore keys are setting lower as they may be in process of breaking off. Once all keys are repaired, carefull lower the top rear cover onto the key assembly. While holding the cover onto the key assembly/base, gently turn the unit over onto its back and reinstall the screws. Should be all washer headed screws - do not over tighten. Check the keys again. Set the keyboard onto its base (if it came with one) and you're done. A little practice and it'll take you less than a half hour to fix the key and get it back together
SOURCE: samick digital piano manual is MISSING! model baby
You might try looking around this site:
http://samick.co.kr/total_html/chap03_total01.html
I don't see your exact model, but there is likely a great deal of commonality with their product...
Might try that GX150 for example...
SOURCE: keys on yamaha digital piano
The keypads can develop dirt , failure of pads which can result in such malfunctioning. If you are able to open the piano then carefully remove the keypads , clean the surface and reset.
this must solve the issue unless the pads/springs/mechanism are having fault.
2. If keys still stuck:
If key is still stuck, use what I like to call the 'jiggle' method.
Keys can become unstick if you jiggle them with your fingers.
You can release the keys by using a flathead screwdriver. Insert it gently between keys that stuck, drive them apart and twist it slightly.
