SOURCE: Need Help with my JVC GR-D750U
You say you have a firewire cable so I'm guessing you realize there is a difference between the firewire cable and the USB cable. You cannot transfer video with the USB cable.
What is your operating system XP, Vista or something else?
When you plug in the firewire cable to the camera and the computer and then turn on the camera does anything happen at all? I cannot recall the exact message, but you should see a small pop-up in the taskbar that something about detecting a DV device.
If you don't see it there may be a variety of problems, but I would still open a video capture application to see if the software "sees" the camera. Windows Movie Maker will work, but I use another product called Scenalzyer. You can download a free copy of Scenalzyer at www.scenalyzer.com. The demo copy is fully functional, but it will leave a "watermark" on your video. You'll need to pay for it to capture video without the watermark.
Assuming you try one of these software packages and you do not have any success I would do the following: right click on My computer and select properties, now select the Hardware tab and finally click on Device Manager. Look through the list and see if you can find something like 1394 Host Controller. If you find it, does it have any exclamation points or question marks next to it?
If none of this helps let me know and we can try some other things. Lastly, I want you to know that I'm not paid for this. It's a strange hobby know, but I like helping when I can. If you find any of this helpful (even if it does not ultimately solve your problem) I hope you will rate this positively. Thanks and good luck.
SOURCE: JVC Model GR-D72U
Check this page--as far as i know JVC is still fixing this problem, but they sure aren't advertising it... http://www.jvcservice.com/service/CustNoticeCamcorder.asp?PgReq=DspDtaDtl&MdlNbr=GR-D72US&Pgm=CCD
SOURCE: EO3 message on JVC GR-D72U
Try this press the record button and hold, then press the manual focus button and release both.
Hope that helps.........
SOURCE: jvc gr-d72u
my laptop does not have dv port.it has only usb port.how can i use dv port of the jvc gr-72u camcorder for capture vdo to my laptop.i tried with usb port.it does not work.
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
