Here is a video that shows how to replace batteries.
https://www.youtube.com/watch?v=qTGvBlGNuXM
SOURCE: can`t get the hand set to lock or unlock, and i ha...
Open the boot/trunk lid and drivers door. Switch on the ignition
to position II but do not start the engine. Wait for the dash
lights to extinguish. within 5 seconds of the lights going out,
Rock the valet switch, in the centre console, 5 times. The system
will chirp to indicate it has entered learning mode.
On models with seat/mirror/steering wheel memory functions,
the first key-ring transmitter will be linked to memory 1, second
to memory 2 etc
Press and hold the larger, lock, button on the key-ring transmitter
whilst watching the Red LED and ether wait for it to stop flashing
or for the system to chirp a confirmation it has got the signal.
If the system doesn't receive any signals for 15 seconds, it
will chirp twice and exit learn mode
To program further key-ring transmitters, rock the valet switch
once. The system will chirp twice for remote number two, three
times for number three etc, then press the lock button of the
key-ring transmitter as above
When finish, wait 15 seconds for the system to time out and
chirp twice, turn off the ignition, close the doors and boot
lid.
SOURCE: no dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
SOURCE: PURCHASED USED SIEMANS 8800 HAND
You need to register the handset to your base to get the phone to work to do this follow the steps in the manual. If you do not have the manual go to the link below and scroll down to product detail then click on the blue product manual.
Gigaset-Accessory-Cordless/dp/B00005UFDR">http://www.amazon.com/Siemens-8800-Gigaset-Accessory-Cordless/dp/B00005UFDR
Or look below to learn how.
SOURCE: westinghouse 522 fridge leaking oil
Hello, Thank You for using FixYa. I will be helping you today.The only thing that has oil is the sealed system. So if there is oil leaking you would have a leak and the unit will stop cooling.Are you sure something didnt just spill and is leaking out?
Thank You and please rate my answer if it was helpful..
SOURCE: Old Milton Bradley hand held
To replace AAA battery in hand held yahtzee game, insert a nickle in the slot (near the top) at the back of the game and slide top section forward.
https://www.youtube.com/watch?v=qTGvBlGN...
