Cell Phones Logo
c
chris Posted on Jul 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there an led alert light on the phone? - Cell Phones
peter
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jul 13, 2018
peter
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
4133
Points
28
Yes there are led alerts on most of the phones but not all. These led lights blinks whenever there are new notifications or missed calls or battery status or charging status .it has different colours to indicate different things.
Marvin
Level 3:
Top Expert:
  • Cell Phones Master 85,242 Answers
Marvin
Cell Phones Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29053142
Points
266281
  • 1 more comment
  • Marvin
    Marvin Jul 13, 2018
    Where does it say that?
  • chris
    chris Jul 13, 2018
    Huawei y6 Elite, my mistake, did not put it down first time I asked the question.
  • ADMIN Andrew
    ADMIN Andrew Jul 13, 2018
    Huawei y6 elite
1helpful
BT Big Button 200: is green led light under 1571 button compatible with Virgin Voicemail messages?
It is a British Telecom phone, so is unlikely to be fully compatible with Virgin phone service. The message is held with them, and just alerts to a message being there.
1helpful
I am trying to use the LED flash for alerts but it will not light up when i receive a call. What am I doing wrong?
in settings, go to general then to accessibility then to LED for alerts and turn on that button/switch
The light doesn't flash when there is a voice mail message waiting. Broken or replace battery?
Hi Mitchell, do you have an iPhone? If so, this link may be helpful: http://m.imore.com/how-use-led-flash-your-iphone-notification-alerts
Let me know if this isn't what you're looking for and what kind of phone you have
2answers
How do I turn phone ringer strobe light on in iPhone 6Plus
  1. Launch the Settings app on your iPhone.
  2. Tap on General.
  3. Inside the General menu, tap on Accessibility.
  4. Scroll down a ways and under the Hearing section, turn the option for LED Flash for Alerts to On.
1helpful
2answers
Light flashes for alerts, texts
Select "Accessibility" and turn the ON switch next to "LED Flash for Alerts"
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
1helpful
Alerts Sounds Just Stopped On My Blackberry 8220
go to profiles. and click advanced options and change it there it will have an option for everytime your phone should ring.. turn the Led light off as a reminder
3helpful
Need to make sure programmed
Program the Midland 74-109 Weather Radio
a) Turn unit on. Extend the antenna. Adjust volume up slowly; Do you hear anything? If not, try replacing the 9 volt battery with a fresh one, in the accessible battery compartment underneath the unit. Repeat above steps.
b) If no sound is heard, turn unit over and look for "WEATHER" slide switch on bottom. With unit on & volume adjusted to comfortable hearing level, slowly slide switch down (or up) through various frequencies [1)162.550, 2) 162.400, 3) 162.475, 4) 162.425, 5) 162.450, 6) 162.500, 7) 162.525] until voice transmissions are heard. This should be the closest National Weather Service (NWS) broadcast for your area. Check the NWS website at http://www.nws.noaa.gov/nwr/nwrbro.htm for your state, click on the state name, and look for the site name or site location nearest you. The frequency for that site should be the strongest, and appropriate for your area.
c) You can set the alert tone, for special weather alert broadcasts, on the bottom of the unit on the slide switch marked "ALERT". Set the switch to the desired type of alert: 1) LED [LED on top of unit (marked ALERT) lights up when alert is broadcast-no siren tone/alarm is heard] 2) LED & ALARM [LED lights up and alarm/ siren tone is heard] 3) VOICE [LED on top of unit lights up and voice broadcast is heard, only; no siren tone/alarm is heard].
d) Be sure to press the "ALERT" button on top of the unit and leave the volume at a comfortable listening level to hear weather alerts for your area (Alert LED on top of unit lights up to show Alert function is active). You can test the present volume level by pressing the "TEST" button. Be sure to press the "ALERT" button again after listening to the volume level to re-set the Alert function. You can listen to weather broadcasts anytime, by pressing the "WEATHER" button. After listening, be sure to re-press the "ALERT" button to reset the Alert function.
e) 9 volt battery life should last about 6 to 7 months, depending on how much unit is used an number of alerts received. Replace battery every 6 months, or when you replace your smoke alarm battery, or at beginning and end of daylight savings time. A 12 volt AC adapter to replace the battery, can be used. One should have been supplied with unit. If not, a replacement can be found at Radio Shack.
f) This should complete your Midland Weather Alert Radio Model 74-109 programming.
2helpful
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
