I also have the Polaroid DVD player remote that goes to the red casing Polaroid DVD Player model DPA-07032S, Lot of people complaining about that INVALID ID KEY onscreen,how/& what is the code do you enter for that INVALID ID KEY?
SOURCE: Universal remote code needed
If you have tried all the codes the manual has it may be the remote does not support your model. Here is a lin to a remote I think will work on ebay:
http://cgi.ebay.com/Memorex-DVD-remote-control-MVD-2022-MVD-2042_W0QQitemZ280186652283QQihZ018QQcategoryZ91388QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You also can try another universal reote brand that might support your unit. Hope this helps.
SOURCE: stuck in 'set 1'
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
Simple solution.
Press the C.Lock key on the remote.
This key tunrs on and off the child lock feature.
cheers.
SOURCE: durabrand dvd player code
Here is the code for the dvd player
0449, 0405, 0446
code for the tv/dvd combo
0189, 0135, 0157, 0153, 0254, 0458, 0217.
website to find the other codes if you need.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
have a good day walmart shoppers.
SOURCE: codes to program a universal remote to this device
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
