Unless the number was displayed in alternation with 888, leave the house and call 911. You need to have someone to check your appliances for incomplete burning, leaks in their exhaust piping or a vehicle that is running inside or too close to an air intake. The 203 is the current carbon monoxide reading. The 888 indicates a self-test and other number is only shown for test purposes.
Please stay safe.
SOURCE: kidde Carbon Monoxide Alarms
YES!!!! If this unit is working properly you should not be in the house. Maximum allowable safety level for an 8 hour period is 50! If you think it's working properly call the fire department! This will cause dizziness,nausea,etc. Let your fire department find the problem! If you don't believe me follow this link to owner's manual but do it quickly: http://www.kiddeus.com/utcfs/ws-384/Assets/KN-COB-B(9CO5)en.pdf
SOURCE: My nighthawk Kidde carbon monoxide detector keeps
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
SOURCE: our kidde battery operated Carbon Monoxide
Relocate it to an area of fresh air - outside will work.. Does it still beep?
If yes, recover the new battery and toss the unit.
Do you have it located in a steamy damp area? Laundry room, bath room etc.. That will cause it to malfunction too..
SOURCE: By LAFYRAD7170 on Aug 13,
If the display shows "Err", push and hold the Peak Level button. Does the display change to "E09"? If so, then you have just been "had" by the grossly under-documented "planned obsolescence feature" called, rather matter-of-factly, "End of Life". This means that ~7 years after first being powered up, the unit will, BY DESIGN, cease to function, forcing you to buy a replacement. Would have been nice of Kidde to include THAT warning on the OUTSIDE of the package. Call their "Hotline" at 1-800-880-6788 and tell them what you think of that policy. If it is still under warranty (5 or 7 years depending on date of manufacture) they should replace it. In any event, buy another one; if they replace your first one you will have twice the protection. Not a bad thing. _ Disclaimer: I am not a lawyer, despite the handle.Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Instructor
SOURCE: carbon monoxide detector err code
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (It's not worth to buy just a sensor). Take a look on amazon: Amazon com Carbon monoxide detector (watch out on reviews). I hope this was helpful. cheers
