SOURCE: the smell of gas
call for service immediatly. dont ever mess with a possible gas leak. it is more than likely a slow leak at the shutoff or the safty valve. your local repair company should have a combustible gas detector. to pin point the leak.
SOURCE: Gas leak within cooktop
What do you mean it has a leak inside? You can remove the glass top by carefully lifting it up and out of the countertop and the removing either the phillips, 1/4" or Torx screws around the lip under the glass. Pull off the knobs and the glass will s-l-o-w-l-y come up with even steady lifting force. Where gloves in case it breaks but it shouldn't as long as you don't drop in on a corner
SOURCE: Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
SOURCE: new cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
SOURCE: Burning plastic smell coming from new cooktop fan.
Sorry - this is not an answer but a question. Did you get your problem resolved. We just purchased a induction stove & oven and are having the same problem you described. Could you let me know what happened. Regards Bob
