SOURCE: diamond shallow well jet pump wont rotate, froze up.
you need to look at the start capacitor, check it with a meter, look at, and spin bearings. make sure they spin free
SOURCE: Removal of impeller and screw - is it clockwise or
The attached may be able to assit you.
http://www.goulds.com/pdf/7381.pdf
Tom
SOURCE: why wont my Jet pump shut off?
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
