Health & Beauty Logo
Reno Sammut Posted on Jul 12, 2018
Salter is registering o-ld what is the reason pls
1helpful
Where can i find replacement parts for Salter 914WHLKR 914 Electronic Baby and Toddler Scale
Error code bathroom scales
O-ld is 'overload'. There are some fixes here. The first thing I would do is remove the battery and leave it overnight. Replace the batteries with new ones. If you think it may be possible that you are overloading the scale, put a bag of sugar or flour on them to test.
https://www.google.com/search?q=Salter+bathroom+scales+0-ld+code
How do I Reset Salter Electronic Scales 9106
Salter 9106 Manuals
https://www.manualslib.com/products/Salter-9106-5886655.html
Salter 9106 Pdf User Manuals. View online or download Salter 9106 Instruction Manual. ... 2. How Does the Salter Scale Work. 3. Faq. 3. Display Guide/Function ...
1helpful
My Salter model 3003 kitchen scale shows Err when I turn it on. How can I fix this?
This means that it cannot calibrate itself because the sensor is out of range. This can happen if you drop it or overload it. Check the feet on each of the for corners and make sure they are not stuck, you can do this with the unit on and see if it registers any force on the pads when you press and release them or use a screw driver to lift them SLIGHTLY. There are a lot of youtube videos on how to check and repair them.
Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Top Salter Health & Beauty Experts
vince
jws1013
Ngoro
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
