The first thing with CD Ejection issues is to try a CD Cleaning Disc. It has brushes to clean the laser optics. They always fail on the low power tracking laser. When it fails self test, it ejects.
also
First unplug power for at least an hour, then press and hold the power/on button while plugging back in, and keep holding for another 60 seconds .
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
