First, I'm not a RediVac or Douglas tech.
* Check your warranty. Call for service, support ;
*** the following is for information only ***
* Eaze Demo (and empty canister); https://www.youtube.com/watch?v=zQL5-7crJ9o
* Storm Demo; https://www.youtube.com/watch?v=TgBJ-azVA_I
* Difficult to locate company (Home vacs). May need to go to Amazon.com or Walmart.com for support.
* Amazon specs; https://www.amazon.com/dp/B005A3PT62
* Douglas Redivac bag at WalMart; https://www.walmart.com/ip/Douglas-Readivac-Vacuum-Cleaner-Filter-Bags-3PK-91051A/927082623
* Another source for bags (note questions line); https://www.ezvacuum.com/douglas-readivac-36600-36610-36610ds-canister-vacuum-cleaner-bags-5-pk.html
Aloha, ukeboy57
SOURCE: Need to change bag
here's the link to the instruction manual; http://sanyoservice.com/pdf/images/SC-180E.PDF (it is for the sc-150 and sc-180) Check page 8 for details. Hope this helps :)
SOURCE: Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
SOURCE: Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
SOURCE: Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
