SOURCE: air cond freezing up after twenty minutes running otherwise is cold
Check for a plugged drain tube outside on the firewall or in that area opposite your heater & AC. Clear it out with piece of wire or similar to remove any debris. Be careful not to poke too hard or deep & puncture heater core or damage any other part. You can usually see liquid on the ground when sitting with AC on, my guess is yours is very limited now, or none at all.
SOURCE: 2001 honda civic bogs out after driving for fifteen to twenty minutes
first you have to chek what codes you are getting . OBD2
then report
SOURCE: is there an oxygen sensor on a 2000 daewoo leganza
yes it has 2 i do not believe thats your problem though have your pump and filter checked and make sur they pressure test it as well im referring to fuel
SOURCE: Crown victoria model 1996 heating up and while
Check your engine area for the heater hose coming from the radiator to the engine. This is where the thermostat is located. Squeeze or tap the hose vigorously to attempt loosening a stuck thermostat. If it still runs hot, find a large drain pan and place under hose on the ground. Wait for the engine to get to ambient air temperature and loosen hose and change the thermostat.
