Washing Machines Logo
Elsabeth Rooney Posted on Jul 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Repair manual for kenmore heavy dty washer model 22442
Terry
Level 3:
  • Kenmore Master 11,377 Answers
  • Posted on Jul 14, 2018
Terry
Kenmore Master
Level 3:
Answers
11377
Questions
Helped
4626392
Points
152765
3 Related Answers
Anonymous
  • 1028 Answers
  • Posted on May 06, 2008
SOURCE: Kennmore 22442
last belt drive kenmore came out in 1986..so doubt you find a belt on it unless you have a calypso model..if you have pump out but no spin motor to gearcase coupling is probably broke
Charles Schultz
  • Posted on Mar 14, 2009
SOURCE: how do I replace a lid switch on a kenmore heavy
I just stuck a wooden clothes pin in the hole to keep the little level in check. My landlord's washer had that problem and he didn't want to pay to fix it. It ran great for many more years after I stuck the wooden clothes pin in it.
Anonymous
  • 1136 Answers
  • Posted on Jul 09, 2009
SOURCE: Kenmore Washer will not drain
Hi, When the the water is suppose to be draingin, do you hear the motor humming at all?
It could be that something is plugging the pump. You can tip the washer toward the wall and look underneath. The pump is right behind the front panel and easy to get to. You can try lowering the drain hose into a bucket and see if the water will release.
Please let me know if this helps you or if I can assist you further.
Vic
1helpful
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
2answers
Believe that my problem can be fixed with a belt replacement but cannot figure out how to get washing machine apart in order to replace. Kenmore 22442 top loader.
this video shows step by step how to replace the MOTOR COUPLER which the manufacture of that washer has used instead of a belt for about 15 years now
http://www.youtube.com/watch?v=9K1KHEogf3c
Part number for that coupler as shown in the video is 285753A
KEMORE WASHER 22442 NOT DRAINING
There's basically a solenoid that should open up to drain.
Please consult your manual for troubleshooting as this model may need a new transmission?
1helpful
Kenmore 90 Series Heavy Duty Top Load Washer Model 110.28922790 water fills in tub and it's draining at the same time. Won't go through the normal cycle just keeps filling and draining. Any help...
You may have a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
How do I replace a lid switch on a kenmore heavy duty washer model # 22442 my switch is in pieces
Kenmore 22442 not spinning unless you physically help it along
Sounds like a worn belt problem!
Call service now before it gets worse and cost you a lot more money!
You'll be okay!
Electronic problem. just call service.
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Give me a good rating on this site , FIXYA.COM
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Kennmore 22442
2answers
Washer not spining
Replace the loose belt. Regarding the dripping oil,look for the defective shock absorber. Good luck!
3helpful
Washing machine overflowing
I'd have a look at your water level detector to start with. Usually a narrow bore hose running from near the bottom of the drum to a pressure switch somewhere near the top of the machine. Most common problem is that the hose gets blocked with gunk. With the machine off and drained, try removing the hose and giving both it and the barb on the drum that it came from a good clean through. A.
Alexander
vince
