Health & Beauty Logo
j
john Posted on Jul 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace the rechargeable battery.(for braun #4501)
Medypharma Medypharma
Level 3:
Master:
  • Braun Master 303 Answers
  • Posted on Jul 12, 2018
Braun Master
Level 3:
Master:
Answers
303
Questions
0
Helped
30412
Points
3678
Https://www.medypharma.com/buy-avana-100mg-online.html Buy Avana 100mg Online, Cheap avanafil online in USA
Michael Hurd
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Jul 06, 2019
Michael Hurd
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
11
Questions
0
Helped
1507
Points
65
Vidalista 40 is the "Weekend Pills" for the treatment of the erectile dysfunction. They help to restore erectile function, to maintain the potency for a long time, to increase the quantity and the quality of contuses. The main active ingredient is Tadalafil (Cialis is a trade name). https://way4health.quora.com/
4 Related Answers
Anonymous
  • 625 Answers
  • Posted on Sep 07, 2007
SOURCE: Braun 4501 shaver
go to the braun site for replacement parts or do a search in your browser for discount braun parts.
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Feb 04, 2010
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Feb 06, 2010
SOURCE: My Braun 5564 electric/rechargeable razor will no
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Oct 02, 2010
SOURCE: How do you get at
You will find replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Start by removing the foil and cutter. Then remove the swivel frame by removing the two tiny screws on each side of the inside of the swivel frame.
To open the shaver you will first need to remove the two round screw covers on the bottom. Then remove screws. You can then gently pry the two halves apart from the bottom
2helpful
Where are the rechargeable batteries located and can any rechargeable battery work as a replacement?
The battery is inside the shaver body. You must remove the rubberized grip to access the screws to disassemble it. You can not use any rechargeable battery. The battery is lithiun ion. The correct battery is available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-liion-barrery-for-pulsonic-model-shavers-p-836.html
2helpful
Will not charge!
The battery is, most likely, the problem and needs to be replaced. To open model 4501 shaver, remove the two round screw covers on the bottom and then remove the screws underneath. Remoe the swivel frame at the top by removing the two tiny screws. Make note as to the right and left side of the swivel frame so you put it back on the same way it came off. You can then seperate the front and back of the shaver by seperatig it at the bottom first. Once opened, you will find a circuit board with one battery attached. You will find a replacement battery at shaveroutlet.com. See link below.
For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
2answers
Not shaving close enough.
This problem is usually cause by a worn out shaving head (foil and cutters). Braun suggests that you change these every 12-18 months for best performance. You will find replacements at shaveroutlet.com for your model 4501 Braun shaver. See link below.
http://shaveroutlet.com/foil-cutter-fit-braun-4000-series-flex-control-twin-control-p-146.html
It is also possible that your shaver is running too slowly due to an old battery if you've never replaced it. If you require a new battery, it can also be ordered from shaveroutlet.com. See link below.
To change the battery you will need to be able to do a little soldering. Open the shaver by removing the two round screw covers on the bottom of the shaver and then the screws underneath. You will also need to remove the foil and cutters and then the swivel frame which is attached by two tiny screws. Once removed, you will be able to open the shaver from the bottom and seperate the front and back. Remove the circuit board to easily get to the battery.
Note: The tabs on this type battery will work for most applications however they may be slightly different than some original equipment. For these instances, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
3helpful
6helpful
2answers
Need to replace 5569 rechargeable batteries
If you are handy and know how to solder (and have the tools required), you can probably do the replacement yourself.
At the bottom of the razor are two plastic caps on either side of the charging port, you'll need to pry them out with a sharp pick or thin knive tip. Once removed, you can get to the screws that hold the front and rear case halfs onto the main shaver chassis where the PCB with the rechargeable battery is soldered onto the board.
Unsolder the battery and solder in the new replacement battery and put the case back together, making sure all the parts are in the correct posistion, and you're ready to recharge the shaver and start shaving again.
To find your replacement battery, try Electric Shaver Service. They also do repairs, so you might want to get an estimate if you don't want to do the repair yourself, etc. They're reliable and fast in getting shavers repaired and back to you quickly. 1-888-476-1785
Here's a link to the page with your battery on it and the toll free number to call for estimates too.
http://www.electricshaverstore.com/search.asp?p=2&w=%5F&c=battery&t=s&m=0
Hope you find this Very Helpful and best regards!
2helpful
How do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Braun 4501 shaver non-function...
You might try the original type battery (rechargable) Batteries Plus has them for less than 3 dollars, and they will solder the leads to the battery FREE! If you were lucky enought to get the 4501 apart, you may have problems getting it back together. Be sure front and back panels are free from the sides and it wont go back together unless you put the TOP snaps in first. Good luck...I got mine going for $ 2.78...
Braun 4501 shaver
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
