Question about NEC Computers & Internet
Why my nec monitor 19" gets off after 5 or 10 minutes and along with their color doesn't working when I do select auto option
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
If you try to plug to other socket and still the same problem.the problem is in youre unit power supply board inside the monitor
Posted on Mar 15, 2019
    Habit-Forming:
  • 97 Answers
What is your power and energy saver settings at? Tap windows key and start typing power sl and power and sleep settings should be the first choice. If its not obvious from there, scroll down and or click additional power settings. And the time out reason should be listed and be changable from there.
SOURCE:
wayez3
  • 20 Answers
SOURCE: NEC 19'' LCD monitor power on but screen blank
If you can try it on another unit , If it still does not work, Then the most likely culprit is a bad power supply. If you know any thing about soldering replace the capacitors they are probably bad but being that these things are being built so cheap.It could also have a bad inverter. not repairable by average dude.If you open it be careful and do not attempt unless you feel comfortable with a solder Iron.Hope this can help you Good Luck. www.IrionsTVshop.com board re builders.
Posted on Feb 29, 2008
jemmyrash
  • 180 Answers
SOURCE: Samsung 19" monitor control problems
Your logic board need to service.
Posted on Apr 20, 2008
  • 1030 Answers
SOURCE: Divergence not working on RCA HDTV monitor 52" D52W26
sound like the common fl231 fuse problem. consult the fl231 problem article under the tips and tricks section. this is probaly the simplest most inpensive repair on this set
Posted on Jan 10, 2009
  • 12 Answers
SOURCE: richo color scanner is760d don't have option auto feeder
This scanner can be controlled by PixEdit so you may scan any amount of sheets. Even easy continue scanning to one document when not enough space in the ADF for the hold stack
Posted on Aug 21, 2009
  • 14 Answers
SOURCE: Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Posted on Aug 25, 2009
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
U screens colors on my pc is too bright
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Oct 05, 2011 | NEC MultiSync 1920NX 19" LCD Monitor
How do I set the NEC LCD194WXM monitor to shut down after 5 mins, 10 mins, 1 hr., etc., etc. Mine stays on all the time!
To change this, do the following:
1) Navigate to the Control Panel by clicking Start and then Control Panel. Then double click on Power Options as shown below circled in red.
2) This will then display the Power Options window as shown below.
3) Once you have opened the Power Option Properties, under Power Schemes select the one that best suits your PC system.
4) Then you can select whether or not to switch off your monitor and/or hard drives after a period of time when it is not being used.
Apr 15, 2011 | NEC MultiSync 1940CX 19" LCD Monitor
My monitor screen is pink, both the background & the letters/graphics.
Go to control panel then settings then Display and it will give you options to change it, the color is also changed by buttons on the bottom of your monitor.
Mar 12, 2011 | NEC MultiSync LCD1970GX 19" LCD Monitor
Can't red and green colors
This usually means the red or green or both primary color module is bad. Monitors come with 3 primary color module controllers and they use them in various combinations to make the other colors. The primary colors are blue, green, and red.
Sep 17, 2010 | NEC AccuSync 900 19" CRT Monitor
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Color
just click on the menu then go to the fourth option [with 3 cirles] in that select the last user option nd decrese as per ur need... it will decrease the colour...
May 21, 2008 | Acer AL1916W 19" LCD Monitor
Cmv monitor bad color
The problem is your monitor, not driver or settings or video adapter cards. You have basically two options get another CRT or LCD display, or if it is still under warranty call the company get a "Return Authorization Number" and ship it back to the manufacturer. I did that with a NEC MUltisync 19" years ago, it turned red, there was little ability to actually change the red image at all. cI Shipped it back to NEC and it has worked ever since. Good luck with your monitor.
PCrx4u
Dec 07, 2007 | Computers & Internet
Screen and colors too bright
CRT and LCD will look different when compared side by side. Is your CRT calibrated, or are they right in the sense that they are what you are used to? Also Anyway, you can adjust the colors and light levels from the menu on your screen, and depending on your operating system and graphics adapter you should be able to make adjustments there, too. For windows XP, right click your desktop and select properties->Settings->Advanced. There might be a color management tab. Also, there might be software to help you do this already installed. Look for a program group with the name of your Graphics adapter manufacturer. Very often ATI or nVidia. A few resources to help calibrate: http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm
May 17, 2007 | NEC MultiSync 1920NX 19" LCD Monitor
NEC LCD1980SX - displaying colored blocks not synchro
Have tried NEC technical Support? This looks like a circuit boatd problem
May 31, 2007 | NEC MultiSync LCD1980SX-BK 19" LCD Monitor
Computers & Internet Logo
32 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
