I push a button for my washer to start and it wont because I am getting a red flashing light in the locked section.
Hi Jen.
not sure if this link will help you out but have a look.
Washer wont stoping flashing in the locked button Google Search
SOURCE: Front Loading Duet Washer will not start
I've got same problem, with the door stuck shut, door lock NOT on, water trapped in the machine, and still no solution. 8 pages of messages and no solution.
SOURCE: Whirlpool Duet washer control lock
hold in the signal button for 4 seconds and it will unlock the control
SOURCE: Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
SOURCE: wont power on
The blinking red light means that the projection bulb ($150+/- online) needs to be replaced. The access door is located lower right side and replacing is staight forward. Sony has a problem with the Grand Wega that it is denying resposablity for. Check it out by Googling "MSNBC problems with Sony Grand Wega". I would like to get a class action suit going.
