Question about Health & Beauty
Our PS-IN202 when turned on reads Ado--- cannot get it to zero so we can weigh animals?
Hi I have a Hanson hx5000 glass bathroom scale Iv changed battery but all it says on the display screen is err any advice please
Try stepping on it lightly and quickly to see if it indicates a zero reading. If that happens, then weigh yourself before the zero goes away.
Jan 10, 2018 | The Health & Beauty
If it says 1 teaspoon of wormer =5ml then how many cc per pound
what you are really asking crosses over from measurement of volume to dosage per weight and there is no method to do that
the direction for dosing will say how many ml to use per pound of animal
so if it is 5ml per pound of animal , weigh the animal and multiply that by the 5ml and you will get your answer
Aug 16, 2017 | Office Equipment & Supplies
Need to reset them they are only weighing up to 7st 11lb and i am heavier than that thnx
if they are digital then turn them on and wait until the dial settles down
it should read zero (00000) stand on the scales and wait until it flashes and then stops at a weight
if it is still 7 stone it could be a battery problem or if they don't read 00000 before you step on them there may be a small screw that can be adjusted to get the first setting right
you can test the accuracy by doing something simple like putting a known weight on the scale ( 1lb of sugar -new packet ) and see what he reading is
keep adding known weights and if the multiples do not equal what is on the gauge reading then they should be returned if new of junked if used
Oct 01, 2015 | Cars & Trucks
Is there a way to calibrate without 3-50 pound weights?
water weighs 10lb to the gallon ( engilish measurement-calculate amount for us gallon)
so get your self a jug and place it on the scales empty adjust the scales to zero
fill the jug with a measured amount of water (example 1 pint will weigh 1.25lbs
then set the scales to the reading of 1.25lbs
to check the scales accuracy you can add extra water to the jug (say 4 pints ) and the scale should read 5lb
Jul 25, 2015 | Office Equipment & Supplies
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
My animal crossing wild world game does not work with my AR
If you use more than 2 or 3 codes at a time it will hurt your ds i dont know why but it just does
Aug 07, 2009 | Datel Action Replay for Nintendo DS
HOW TO WEIGH THINGS IN MICROWAVE
the microwave does not weigh things. you need to know the weight for things like auto defrost.
1 pound ground beef... enter auto defrost ..10
will read 1.0 ... 1 1/2 pounds... enter 15 ..reads 1.5.... 1/2 pound enter 5...reads 0.5 . unit beeps half way through heating program.. open door.. turn meat over close door. will continue to defrost
Jul 02, 2009 | Microwave Ovens
Linking vb to access
You post it in the wrong product, you should have posted it in Access or Office. But I will try to answer anyways...
In tools look for references and then look for MS ADO Data Control 6.0 or Microsoft ADO... Just select it and press ok then you will have a new control object name "ADO data control". See the explanation about the ado data control which is very easy to use...
Here is also a great tutorial for the ADO Data Control:
http://www.devarticles.com/c/a/Visual-Basic/Implementing-An-ADO-Data-Control-With-VB6/
You can also use VBA in Access, you have exactly the same functions there as well.
Sep 19, 2007 | Adobe Photoshop CS2 for PC
Health & Beauty Logo
431 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
