Question about Jacuzzi Home
I have a marlin jacuzzi 1904499 push button nothing ,checked power ok Is there a manual for this jacuzzi
    Top Expert:
  • Jacuzzi Master
  • 19,466 Answers
Look online using make and model or check manufacturer site for one
Posted on Jul 10, 2018
SOURCE:
  • 7 Answers
SOURCE: Push power button nothing happens ?????
Hmm. There should be a hole you can empty the water tank. Please check if it is full of water and try reconnecting it.
Posted on Jul 07, 2009
komguy
  • 2306 Answers
SOURCE: alert light on says to press ok button, nothing
That's an older model, it gives no error code until you enter service mode and get the code. Service mode is only available to service techs since there several things you can do in there that could ruin your printer. You can find the nearest Canon service by calling 1-800-828-4040
Posted on Feb 04, 2010
  • 990 Answers
SOURCE: Recently purchaced a house with jacuzzi tub.
Two things come to mind; First check to see if there is a GFCI on the box or the power cord and be sure it is not tripped. Also be sure that the covers are all as their are quite often magnet switches on the doors that will kill all the power if the doors are open. Good luck.
Posted on Apr 01, 2010
uspartscente
  • 719 Answers
SOURCE: how to fix air button on my jacuzzi tub. when i
Air Buttons have a threaded body that has a nut on the underside of it that holds it in place. You will need to get the under the tub to get that nut off the button body to remove it and get it changed.
Posted on Jan 12, 2011
SOURCE: I push the on button and nothing happens. is it
Computer was plugged in to a power strip , computer was in use when power strip was shut off accidentally , now computer will not start back up .Have checked everything even trying a new power cord , still nothing not even a sound when power button is pushed. can't seem to find a reset button , but still looking .Is my computer dead or is there a simple solution or a reset ?
Posted on Mar 11, 2011
Jacuzzi majic touch won't turn on
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Nov 28, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Asteria will not turn off
How do you turn this on? If it is an air button that you push, it may well be the air switch in the motor is bad. The air switch is latching so when you push the button on the tub it closes the switch and lets the power go to the motor. When the button is pushed a 2nd time the switch will open and shut off the power going to the motor.
An air switch will cost about $21 to purchase.
Rod
US Parts Center
Aug 23, 2013 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Where can I get a user manual for Carslbro Marlin 8400 DSP power mixer amplifier
Try Googling (Carslbro Marlin)(8400 DSP)(manual) without parens.
Jan 17, 2013 | Audio Players & Recorders
My jacuzzi motor is not working
When you push the button and the motor does not turn on there a couple of things to check.
Is there power to the pump? check the circuit breaker
If there is power to the motor then the air button on the top of the tub may be bad or it could be the air switch inside the motor.
Rod
US Parts Center
521-6183
Jan 11, 2013 | Jacuzzi Home
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Recently purchaced a house with jacuzzi tub. Filled tub with water and pushed on button. nothing happened. There is power to outlet.
Apr 01, 2010 | Garden
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Sep 30, 2009 | Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB...
Home Logo
51 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
