Garden Logo
P
Patrick Budler Posted on Jul 10, 2018
Clip Director on my Honda mower has come loose, cannot move door from mulch to bag. How do I fix this
5 Related Answers
Anonymous
  • Posted on May 10, 2008
SOURCE: Saw your post about Black and Decker MM525 Lawn Mower
With the Black and deckers, I think you just take the blade off and turn it over. That wil direct the grass clippings down into the ground.
Anonymous
  • 205 Answers
  • Posted on Mar 21, 2009
SOURCE: The electic mower abruptly quit working. No previous problems
You can get a manual from www.searspartsdirect online. should have a troubleshooting guide to help you determine cause.
Anonymous
  • 246 Answers
  • Posted on May 16, 2009
SOURCE: Grass clippings won't go into bag
Hello steveacosta:
Check the Blade. If the Lift Area Behind the Sharpened Area of the Blade is Worn, then you will have the Problem you Described.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
nathan
  • 634 Answers
  • Posted on Jul 06, 2009
SOURCE: Mulching blade replacement for Toro GTS 6HP
goto toro website and use model of machine to get blade model and use blade model in google to get prices and then order them
Anonymous
  • 95 Answers
  • Posted on Jul 30, 2009
SOURCE: I would like to replace the mulching blades on my
The straight blade for the 42 inch mower is 138971.They cut better and are easier to sharpen and you will need them if you use a gass catcher. If you do not want to use sears for parts you may be able to find good deals on ebay.
2answers
How do I adjust mower to mulch position
That question requires a lot more info; what kind of mower, push or riding, how big in inches is the deck. Does it have a bag? But typically, the blade is what will do the mulching. Make sure you have a mulching blade. If you have a bag, take it off and ensure the chute where the grass comes out is closed so the grass does not get thrown out from underneath the deck. I hope this helps with the info provided
Oct 18, 2018 • Garden
How do I free up a (mulch or bag lever)?
if this is a Honda mower you have to get underneath and remove the plastic cover... you can screw stuff up quickly with this job... if it's not a Honda, you should of mentioned the brand
Oct 15, 2014 • Garden
Replacement grass catch bag for Black & Decker mm600 electric mower
It appears that you will need to contact the service center as in your parts diagram, the bag is not listed. A mulching blade is listed, which doesn't require the use of a bag.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=MM600&selectedType=4882
This is my second mower. First one damaged after hitting a rock. My replacement mower will not discharge grass out of the side discharge. I have the mulching attachment in and the discharge chute as...
it could be a low lift blade on it. try to get gator blade for mulching..... or a high lift blade. lol, size does matter!!! this may fix the issue. there is so many blades out there now, experiment till you find what your looking 4......
2helpful
2answers
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
2answers
How do you change from bag to mulch?
You will need your model number. Go to www.toro.com. Put in your model number.
I know there is a plug you can put in the chute and it will turn it into a mulcher. Without your model number, I was not able to come up with a part number for you.
Good Day.
Oct 16, 2009 • Garden
I need to change the blade, but am unable to loosen the nut holding the blade in place. the nut and square spacer underneath move together.
you need impact gun.air or electric operated impact,run it reverse. it shouldn't be loose like that. i am guessing the armature drop could be the ring is out of the armature groove. ring are located inside the motor assy.
Blade assembly does not tighten
check out toolpartsdirect.com for parts diagram.
Craftsman 6.5 lawnmower
The bag return on the 6.5 sits on two hooks. Standing to the left of the mower you should be able to grab the back handle with your left hand and then left the metal protective flap with your left hand so you can raise the bag assembly still in your right hand up and out of the two hooks. You'll then need to put back into the mower the mulching kit which blocks the rear discharge and makes the underside of the mower a complete circle so the mulching effect works. Obviously the mower will physically work without the mulching kit because the metal protective flap will cover the rear eject but it will NOT effectively mulch the clippings and you will get longer pieces that clump.
Hope this listing isn't too late to help.
sean
5answers
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
[email protected]
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
