SOURCE: unlock my nokia 6300
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
The default security code for Nokia is 12345
IMEI: 356261010700860
Master code: 1130600407
Take your SIM card out first.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only. You type in the security codes (anything) until the phone request the Master code; when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
"Confucius he say: He who stand on toilet, is high on pot."
SOURCE: Unlock Security Code Nokia 6070
IMEI: 353664011528698
Master code: 3564155064
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
If it doesn't request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
SOURCE: Forgot security code for nokia 1110i-rh93
Hi Friend,
The security code is as follows,
For Nokia 1110i--------3777476375
For rh-95------------------6017702052
Regards,
Ayyasam
SOURCE: nokia 3500 classic forgot security code...
my nokia3500c foget code,idont no my emi number.how to solve?
