SOURCE: Lens problems... kind of
Hi
Love it, I wish everybody did this thorough of a job when posting a problem! Is the camera out of warranty? If not call up Canon for a warranty repair.
I agree that it could be a software problem, try and see what you can do yourself with what you can find online and also reset the camera to the default settings as well. This gives us a baseline from which to work.
If you can't find a solution with software, then it's time to try hardware. Always remove the battery before you open your camera! You can start by taking the camera apart and re-seating the flex cable for the lens and CCD, it may or may not do anything. Don't turn on the camera without the body on, you don't need to put the screws back in through, just put the body back on first. If this doesn't work then it's time to try a new lens.
You can look for a defective camera online and see if you can make one from the two, or you can find somebody that sells parts and does repairs for a decent price.
Don't bother
trying to send the camera to Canon if it is out or warranty (though you can call them and verify
what I'm about to say) because they will want $150+ to do the repair
for you. Parts are not cheap to buy from them.
I know of
one very affordable digital camera repair business... because I own it.
The name is Darntoothysam, feel free to check us out, we are on that
big auction website also (I don't plug their name for free), our seller
ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
We
have your repair listed as a package in our store for about $70. This
covers a new lens, and return shipping of your camera! We even give a
45 day warranty on parts and labor. If you think you can use us then
please check us out, even if you need to ask more questions then please
feel free to contact me.
Hope this helps,
Thomas
Darntoothysam com
SOURCE: Film Advance Lever and Shutter Curtain
If the film advance lever is "flopping" back and forth, the problem is most likely a jammed advance mechanism inside. The shutter is cocked *mechanically* and released the same way--no battery power is needed. One old trick you could try to release things is to push the rewind button on the bottom of the camera.*sometimes* it will free up the mechanism enough to unjam.
SOURCE: My Olympus vg120 switches on
Sounds like it has been dropped and is off track/set .As long as it wasn't broke electronic tech could fix it. Dont spend much tho cause they are around 75 bucks online now.
SOURCE: The lens won't come out
Hi.
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
SOURCE: My shutter won't fire using
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
If a lens has an "A - M" switch, move it to "M" to manually focus. If the switch
says "M/A
- M " then leave on M/A (unless you're going to be taking several or more in manual mode), as these lenses may be focused manually at any time in either position. As soon as you tap
the shutter button in M/A you return to autofocus.
More advanced lenses, like the 18-200mm, 70-300mm VR and 18-135mm,
and any lens with an M/A position, may be focused manually at any time
without moving any switches. Leave them in their A or A/M positions.
I hope this helps and good luck!
