Your Service Manual is here:
Asko W600 Service Manual
Try pages 20 ~ 22
Anthony
SOURCE: Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
SOURCE: asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these:
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If
the motor is running, your washer probably has a frozen pump pulley or
a broken pump belt. To check the pulley, remove the pump from the
washer and try to rotate the pulley manually. If it doesn't turn
freely--if it's frozen or stiff--replace it. If the pump belt is broken
or looks quite worn, replace it--but be sure to check the pump pulley
before you change the belt.
If
the motor isn't running, the lid switch may be defective. If so, the
washing machine can't spin and may not function at all. The switch is
inside the washing machine main housing near the door frame. Often you
have to raise or open the top or front of the washing machine to get to
the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The
lid switch may be defective. If it is, the washing machine doesn't
spin. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the
washing machine to get to the switch. If it's defective, you need to
replace it.
The
motor coupler may be broken. Many Whirlpool®-manufactured washers use a
small, relatively inexpensive motor coupling. It's plastic and rubber
and is mounted to the shaft of the motor on one side, and to the
transmission on the other. Over time, the coupler wears out and fails.
You may need to replace it.
A
belt may be broken. Many washing machines have one or two belts. If a
belt is broken or badly worn, you need to replace it with a genuine
belt from the manufacturer. (Some washing machine belts are designed
with special characteristics not found in automotive belts.)
The
clutch may be worn. If your washer is a GE, it may use a clutch to come
up to the proper spin speed. As the clutch wears out, it may prevent
the unit from spinning well or at all. If the clutch is worn, you need
to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
The
drive motor may be defective. Many washer brands use a reversing motor.
For agitation the motor runs in one direction, for spinning and
draining, the other. It's possible for a motor to burn out in one
direction and continue to operate in the other. If this happens, you
need to replace the entire motor.
The
spin bearing or basket drive may be worn or seized. These components
allow the inner tub to spin freely inside the outer tub. When this is
the problem, you usually hear a loud sound during the spin cycle. Call
a qualified appliance repair technician.
It spins only with the lid closed
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models
If the coin trap in the drain is clear of debris, try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jurgo
Hi
First
make sure that nothing is blocking the drain pump assembly located inside the
bottom of the unit, after this test the door lock-switch assembly. If the door
lock-switch is also fine then the control board should be replaced. Hope this
helps...please post back for further assistance.
Daniel
