How do I make a correction if I can not sign on, it was a big mistake Help please
See a FULL user manual here:
http://office.manualsonline.com/manuals/mfg/casio/pcrt500.html
DOWNLOADS the FULL PDF Manual here:
http://support.casio.com/storage/en/manual/pdf/EN/014/SE-S800_NA_EN.pdf
Anthony!
Testimonial: "Thank you so much , now I am making progress"
SOURCE: CASIO PCR-265P
In Reg Mode I pressed the number 1 and %/CLK# button.
I manual is not clear about setting CASHIER ID NO. 1-8.
SOURCE: extract data from a casio te 3000 cashier
Hi.
The common software is CasioVision (CV). Check with a local dealer for software and cables.
SOURCE: Program a cashier onto a Casio TK 7000
It should be the 05 file on that machine so you just add the cashier number in front of the file number (105 for cashier 1, 205 for cashier 2 etc). So go to program 2 then use the 05 code as I've said to edit the text. The text entry procedure is shown in the manual so just run through that to familiarise yourself.If you don't have the text entry information in your manual, then you have the wrong one. You need this one:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-6000_TK-6500_TK-7000_TK-7500_TK-T500_CE-6000_etc_dealer_manual.html
