Here is what one said:
"To clean it, you will need a small paint brush, screw driver either flat or crossed, then disassemble it. Loosen the screw and just be observant what you put apart. Then clean it. Good"
You may want to take it to a gas station and REALLY clean it out? OR a aerosol canned "AIR DUSTER" will be very useful too!
You need to clean it and oil the bushings. When this doesn't solve the problem, change the start capacitor. If it continues to hum or make noise, replace the bushings. A repair technician may be helpful.
Open the grills and use a long stem tipped with cloth dipped in kerosene to lightly clean the dust. Then use a similar arrangement of dry cloth wound on it to wipe clean the moist dirt. Repeat the process and you will have a clean blade. Use a jet air blower to assist you , use face mask and do it out in the open.
Helpful ?
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
May not be identical but an appliance store or hardware store should be able to assist you with that. Home depot or Lowes as well. Take old one with you if you can.
