Health & Beauty Logo
Vicki Laughlin Posted on Jul 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why my hooverround scooter keep beeping when I turn the key is on
Anthony Cardenas
Level 3:
  • The Master 757 Answers
  • Posted on Jul 09, 2018
Anthony Cardenas
The Master
Level 3:
Answers
757
Questions
11
Helped
387027
Points
5327
"Apparently" it MATTERS how many beeps you have? Your Scooter is trying to communicate with you!
Please see this series of posts:
https://www.mobilityscootersdirect.com/forum/knowledge-base/pride-go-go-mobility-scooter-beeps-5-times
4 TIPS TO RESOLVE COMMON MOBILITY SCOOTER AND POWER WHEELCHAIR ISSUES
4 Tips to Resolve Common Mobility Scooter and Power Wheelchair Issues
Anthony
3 Related Answers
Anonymous
  • 177 Answers
  • Posted on May 28, 2010
SOURCE: Scooter just beeps when key turned
Hi. That fault is the speed lever. It can also be the small dial that alters your top speed. It pays to replace both of these at the same time. Some of these machines also develope the same fault from a faulty controller. Good luck. Neil.
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Dec 16, 2012
SOURCE: constant beeping but scooter will move
okay there sounds like there either water somewhere or condensation ?
place the whole scooter in a warm room next to a radiator, not too close but close enough so it gets the warmth leave it like this to dry out, this has worked for me, water causing a short either under the tiller panel or where the controller is situated.
regards
alchiecez27
Archie Cruz
  • 641 Answers
  • Posted on Apr 24, 2014
SOURCE: How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Lights will not turn off and after turning on scooter in a few minutes, hear a beeping
If the lights on your Golden 3-wheel scooter won't turn off and you hear a beeping sound after turning it on, it could indicate a potential issue. Here are some troubleshooting steps you can try:
  1. Check the key switch: Ensure that the key is inserted fully into the key switch and turned to the correct position. Sometimes, if the key is not fully engaged or turned properly, it can cause electrical issues. Try removing the key, reinserting it, and turning it to the correct position.
  2. Examine the battery connections: Inspect the battery connections to ensure they are secure and free from corrosion. Loose or corroded connections can affect the scooter's electrical system. If you notice any loose or corroded connections, carefully tighten or clean them as needed.
  3. Verify the charger connection: If the scooter is connected to a charger, make sure it is properly plugged in and connected to the scooter. A loose or faulty charger connection can cause electrical malfunctions. Try unplugging and reconnecting the charger to ensure a secure connection.
  4. Check the scooter's manual: Refer to the owner's manual or user guide for your specific model of Golden 3-wheel scooter. It may provide troubleshooting steps or information about the beeping sound and lights issue you are experiencing. Look for any error codes or indications that can help diagnose the issue
Why does it beep five times when key is turned on and controls won't work
hi, the 5 bleeps are related to the brake,,, located at the rear of the scooter located on the side of the motor, attached to that is the free wheel lever,, in drive mode ,, check that the microswitch is working correctly, check the wire( connectors etc ) from the brake to the controller ,
www.facebook.com/gewizrepairs
2helpful
2answers
Hi Mag,
Possible Cause:
3helpful
2answers
5 beeps when turn on key
5 Bleeps -> The manual freewheel lever is in the(forward) freewheel position.Remove the key from the keyswitch, then push the manualfreewheel lever to the drive(rearward) position and restart yourTravel Scooter.
I strongly advise you to check the freewheel lever microswitch located on the side of the motor, also check the connection from the axle connection to the actual body were it comes apart. keep me updated please. regards GeWiz.
2answers
Scooter does not move either direction. when i insert the key i get 10 fast beeps and the 9 slower beeps
This scooter has an S drive controller. The beep code will begin with 10 very fast beeps followed by a number of slower beeps. The number of slower beeps indicates the actual code. It will do this only once. To repeat the beep code, remove and reinsert the key.
Beep code #9 is a possible controller trip.
Diagnosis:
The key may have been inserted during battery box installation.
The controller may be overheated.
The brake is dragging or pulling too much current.
Solution:
Remove the key from the key switch before installing the battery box.
If the problem persists shut down the scooter for 10-15 minutes and allow the controller to cool down.
Bottom line is that you may need a new controller or brake. Keep in mind these may be warranty items. A qualified technician may be needed to diagnose and repair the problem. Hope this helps.
2helpful
1helpful
2answers
Pride "Celebrity XL Deluxe" 4-wheeled Mobiltiy Scooter
Sounds like your motor brake is out. Usually the discolor on the brake indicates it has overheated.
Top The Health & Beauty Experts
Paul Carew
Steve Sweetleaf
Steve Sweetleaf
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
