SOURCE: Volvo-penta aq271c, trim will go down, but not up.no pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
SOURCE: How do I find where the hydraulic pumppower trim is on a Volvo penta ad31 boat motor
Mounted to the inside transom. Usually on the starboard side.
