Kitchen Ranges Logo
R
Robert Christensen Posted on Jul 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool accubake oven display has gone so dim that I must turn lights off in kitchen to be able to adjust the oven. Is there a replacement bulb or panel or known fix? Bob & Janet
Anthony Cardenas
Level 3:
  • Whirlpool Master 757 Answers
  • Posted on Jul 08, 2018
Anthony Cardenas
Whirlpool Master
Level 3:
Answers
757
Questions
11
Helped
387837
Points
5327
MMMMmmmm see this:
eBay: $44.99 (OR BEST OFFER!) NEW
391847690458
$10 shipping
Here is a USED panel, eBay ~ same price:
Whirlpool AccuBake Oven Control Panel 8304270 8304243 eBay
Whirlpool Accubake Oven Control Panel 8304270 8304243 NEW
Anthony
(Say Thank You!)
5 Related Answers
Anonymous
  • Posted on Sep 05, 2008
SOURCE: whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
Anonymous
  • Posted on Apr 10, 2009
SOURCE: dim LED display on oven
You need to replace the capacitors on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
visitor191
  • 3 Answers
  • Posted on Jul 10, 2009
SOURCE: Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
Anonymous
  • Posted on Jul 15, 2009
SOURCE: Dimming temperature and clock light on display window
I found capacitor c3 (68 uf 35 volt) had leaked and dried up, causing the display to fail. I unsoldered and tested c1, c4, c7, and made sure they were good, using a digital multimeter with the ability to test capacitors. C3 also had visible signs of leakage. Works like a charm again, and the display is bright like new!
Anonymous
  • 6784 Answers
  • Posted on Dec 28, 2009
SOURCE: Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Testimonial: "Thank you so much. This is a job that my husband can do to fix it."
Oven and broiler won't light
You may need to replace the part called the igniter module. It is what creates the spark that fires the gas.
Started baking with my whirlpool accubake dual
It sounds like the electronic control has gone bad. It may be possible that the thermal fuse to the panel has gone out. many Whirlpool panels have a thermal fuse that attaches to the panel. If it goes out the panel will not have a display.
Whirlpool accubake oven stuck in celcius
How do I get my Maytag that is a year old back to Farenhient from celcius
I have a ge accubake double oven and the clock/temp display is very dim? What do I do?
unless it has some type of a dimmer control you would need to replace EOC {electronic oven control}
2helpful
2answers
How do you change the oven's light bulb? How do yu get the cover off? no clip won"t turn counter clock wise. Whirlpool Gold accubake duo system
I couldn't get my cover off either. My solution was to use a pipe strap wrench, very carefully. Rotate the cap counter clockwise to remove it.
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
