SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
SOURCE: 08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
SOURCE: kENMORE DRYER HAS FLASHING LIGHTS
The f26 error code indicates that the control board in the dryer detects a drive motor system failure.
