SOURCE: headset buttons
press both the volume buttons together for a few seconds... light should flash red & blue
SOURCE: user manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
SOURCE: LG HBS-200 Headset w/Bluetooth. Phone works. Music does not.
iphone works well with LG HBS 200, I am listening to music in iphone though LG HBS 200 right now..it works like charm
SOURCE: Iphone does not pair with LG HBS-250 Bluetooth Headset
the bluetooth of iphone is not compatible with this.get the bluetooth application installed from itunes store to maki it compatible.
SOURCE: LG HBS-200 Bluetooth Stereo Headset user manual
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
User Manual
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device,
then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
