Have a pioneer vsx1122. Only get sound from main speakers when playing music. Would like to also get sound from subwoofer and "B" speakers which are outside. All speakers test find in menu test sound field setup.
Hello John, to get sound in the "System B" really called "Zone 2" you have to select in the menu, which sound source will come out through this output and there you will have the solution
In the user manual it is well specified
Hola John, para obtener sonido en el "Sistema B" realmente denominados "Zona 2" tiene que seleccionar en el menu, que fuente de sonido va a salir por esta salida y ahi tendra la solucion
En el manual de usuarrio esta bien especificado
https://data2.manualslib.com/pdf2/44/4378/437730-pioneer/vsx1122k_operating_instructions.pdf?4c787a85640d8c79c964ed8b0fc26af7&take=binary
SOURCE: Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
SOURCE: Only getting 2 speakers working, not 5.1 surround
Try the DYNEX driver:
http://www.dynexproducts.com/p-190-dynex-51-channel-pci-sound-card.aspx
SOURCE: Klipsch subwoofer doesn't work with Pioneer receiver
Make sure the subwoofer is hooked up correctly and powered. Also, be sure to make sure the subwoofer is turned on in the Head Unit's settings which can usually be accessed via a button on the face of the Head Unit.
Best Regards,
James
SOURCE: Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Either the sub woofer speaker or the sub woofer amplifier section circuit has the fault. Contact any service technician to make diagnosis the faulty section. If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
