I had the Power Acoustik pmd 112 installed professionally Installed in my 2017 Chev express van. They say it is what it is.
SOURCE: low power when accelerating
I thought the filter might be the issue here, on carb cars the engine tends to stall out with a plugged filter.
SOURCE: 2009 chev cargo van sways all over the road. I'v
Sounds like sway bars may be too light for the load in the van. I don't know your specs for this but may have to get heavier set and put on both front and rear to help stabilize. If you have some racing buddies they can explain...
SOURCE: how do I reset the "service engine soon" light - 2000 chev
disconnect the + lead to the battery for a bout 3 minutes then reconnect
SOURCE: 04 chev express 350 van shift stuck in park, help?
have you possibly got the steering wheel jambed to the far right or left against the curb, if you do you need to force the wheel further to unlock it
SOURCE: 98 chev tracker, low power, bogs at low rpm, high
Whats the actual code? If you can tell me that I can tell you how to fix it.
