SOURCE: leakin air cylinder on my daisey model 3880 bb gun rifle
The o-ring or gasket is worn and can't take more pressure after the 5th or 6th pump, you should be able to get a gasket kit for it from your retailer. Hope that helps!
SOURCE: I took apart my crosman 2100 classic .177 caliber
go to the crossman web site and see if they have a service diagram for that weapon or call their tech department and ask if the can send you a diagram on that model so you have somthing to go by next time take a table put numbers on it and place each piece under a number as you take it apart then just start from the highest number and go backward till you finish it thats ho the army dose it
SOURCE: I need a manual for a crossman Model 160 pellet rifle
Here is a link to the entire Crosman manual. Scroll down the page to the 160 model and download the owner's manual free.
http://www.crosman.com/airguns/service/manuals/crosman-rifles
Testimonial: "This was a termendious help. Thank uou very much Charles"
SOURCE: i took apart my crosman .177 pellet rifle, and
See the answer:
http://www.fixya.com/support/t4047835-put_trigger_back_together
SOURCE: How do I adjust my scope on my Crossman bb/pellet rifle .177
Assuming the scope is ok, and the gun is ok, it must be the shooter, Not you but the stance, holding, bench rest, something is not consistent. If I was you, I would set up a big piece of cardboard at 15 yards, get the rifle on a beanbag or a bench rest, aim at a one inch spot in the center of the cardboard, shoot about 3 times, depending on where the pellet is hitting, move the adj knobs accordingly, do it again, 3 times, adj, as many times as it takes, get it centered, then, shoot it about 3 times at a clean plate, if it hits it's mark 3 times, then you can try it standing, and you should be able to build confidence in it so you know where it shoots, and won't be discouraged. Now if the rifle is bad, or the scope mounts loose, you will fight the thing all day and end up trashing it. I would blame the mounts first, then the scope, then the rust spot in the barrel, rare. If it is a break action rifle, you can set it up in a box with v's cut into it, look through the bore at the target, make sure it doesn't move, the scope should be looking at the same exact thing, if it isn't, something is wrong. You can set it up this way to start, and then fine tune it with pellets. Check it out, hope this helps.
