SOURCE: Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
SOURCE: amana oven
Error
F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press
cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the
lock, which is held in place by a tiny micro switch. If not and while
the electric is still off or the oven is unplugged, use a bright light
flashlight to look through the slot where the lock is in the oven, not
in the door.
You may be able to use a thin blade screwdriver to move the lock to the
release position. Check the angle of the lever. A slightly bent lever
handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to
access the locking device and release it. May have to disconnect the
wires to the lock which will allow door to function but not during any
self cleaning modes.
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Hi
F9 is a door lock error and to solve this issue you can hold
the light switch for 15 seconds, this will reset the control. If it won't work
then hold the light switch in and set the unit to clean and after a minute
press cancel to cancel the clean cycle. If still it won't work then the door
lock assembly should be replaced. Hope this helps...please post
back for further assistance.
Daniel
Hi
Daniel
Hi
The door
lock assembly is bad and should be replaced, you can try to move it but that
won't help and will have to be replaced to solve this issue. Hope this
helps...please post back for further assistance.
Daniel
