Update: Thank you all for your comments. It appears something is wrong with the thermostat. It doesn't matter where I set it. It is blowing up pop cans at 1 and max. The only setting that works is off so I guess it is time for a new fridge.
SOURCE: thermostat setting on frigidaire bar fridge 1 - 10
10 is the coldest. Hope this helps you:) I keep mine at 6 and its great.
SOURCE: the temperature gage is a wheel on the right hand
1 is warmest-7 is coldest
Testimonial: "fabulous thanks"
SOURCE: What is the climate control
9 is the coldest
Testimonial: "Thanks we use it primarily for beverages but food doesn't last long - we ruined our turkey in Nov of '09"
SOURCE: Turned the fridge temperature up
Keeping 3 to 5 degree is good. But check freezer is frosting good. If ice formation around the freezer is over, it will abstract the fan by functioning. If so, check defrost timer, thermostat and heater for not malfunctioning.If defrost cycle is good, there would be constant cool in fridge compartment.
Thanks.
SOURCE: LG fridge freezer gwl227ybqa soft touch controls
with all five bars lit up it be at its coldest and vice versa when one bar is lit it will be at its warmest
What fridge 1 is coldest ??? If the thermostat starts at 0 the an goes to 9 9 would be the coldest
