I need a manual and to know the radio of gas and oil
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
SOURCE: I used poulan 2 stroke weed eater engine oil in a
Check your fuel mixture and remove the spark plug and clean it.
SOURCE: I need to down load the ower manualfor troy bilt
here is the manual. Just click the file to download instantly.
1. 769-04481_TB539E_Operators_Manual.pdf
Please don't forget to give this answer a four thumbs up rating.
Thank you for using Fixya.
Alp
