SOURCE: remote control for koss 220
Well, I had the same problem, so I open the control and clean with a little alcohol or acetone the panel inside. Now I got my Koss control working 100%
Hope this post help.
SOURCE: disk stuck in Koss c928. DVD powers up and says
There should be a small hole on the door of the disk tray. insert a paper clip in the hole to manually open the disk tray. remove the disk and see if the tray will open and close normally. If it does put another disk in and see if all is well. If not I would have a repair center look at it.
SOURCE: I need a replacement remote for a Koss KS 4192
hi! i have here a couple of codes for KOSS home theater system, just try them 4003, 2060, 4015, 2200, hope this helps!!! goodluck!!!
