SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
SOURCE: Have a Leisure roma 100 cooker model number
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
SOURCE: Just bought a Leisure Gourmet Classic gas cooker.
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
SOURCE: i have acquired a leisure rangemaster 110 dual
I know the answer. You ,must set the clock else the oven(s) wont work.
Phone number for the company you might call for assistance or a copy of an owner's manual.
http://cdn.cnetcontent.com/a3/5a/a35af01...
0845 600 4916
UK: 0333 207 9918
IRELAND: 01 691 0162
Opening hours for UK and Ireland: Monday to Friday: 8am - 8pm. Saturday and Sunday: 9am - 5pm
http://www.leisurecp.co.uk
https://www.leisurecooker.co.uk/support/...
I searched but did not see that model number GR6GVKP
