Hello people, I need to view .mpp files and share with teammates. I need reliable solution that will keep my files save. Is there anything you might know? Thanks!
Here are a couple free viewer options for MPP files: I did not cross reference the sites with virustotal.com (free online virus checker owned by google that checks URL's against 70 or so virus and malware checkers)
MPP Viewer is a simple viewer for Microsoft Project files. It allows you to Open, Export to excel, Print mpp files. It works well with Project 2016 / 2007 / 2003 / 2000 files. Allows hierarchical view of tasks, resources view and more.
Mpp Viewer download ' SourceForge.net
https://sourceforge.net/projects/mppviewer/
Open any Microsoft Project MPP file from your device, network, intranet or cloud location.
Free Viewer - Project Viewer Central
https://projectviewercentral.com/freeviewer/
SOURCE: cannot open mpp files on project viewer cintelic
The reason of impossibility of opening .mpp files can be in their corruption.
You need to program way of solving problem out. I should recommend you tool below
http://www.project.fixtoolbox.com
SOURCE: How fix .mpp file?
If you can't open the file in MS Project, and none of the other MVP FAQ methods are working for you, then the native libraries in VBA aren't going to be able to open it either I'm afraid. However, that's not to say it's irrecoverable just yet. Here are a couple of ideas:
Different Version of Project - You don't say which version of MS Project you're using, but I've had a corrupt file in the past which would not open in 2007, but we were able to open it in 2010. If you can get access to another version of MSP then that might fix it (I have an instance of 2010 available now if you want to send the file to me to try).
2013 has been available for some time now - I've not used it yet, but it may be even more robust than 2010 when it comes to handling corrupt data. Different Application - There are a number of viewer applications out there - just google "MPP Viewer", and as they don't use the MS libraries, they may be able to open files that MS Project can't.
Some of these applications are free, and some are free and online, so you may be able to get access to the data that way. the only viewers I've used give you a means of viewing but not saving the project file, but you may be able to copy/paste data into a fresh MPP file. Recent Back-up - I assume you've exhausted the possibility of getting a recent back-up of the file? You'll have lost some work, but redoing a couple of days work on the schedule may be less painful than the next option... Bespoke Coding Using MPXJ - There is a library called MPXJ which allows you to access MPP files from within .Net.
If you absolutely had to get this data, then you could write a VB.Net application in Visual Studio using this library, and there's a chance that this library may give you access to the data. Once accessed, the library allows you to save in other formats (i.e. other than MPP) which you may then be able to reopen in MS Project, then resave as an MPP file. It's a nuclear option, and is likely to be expensive and/or time consuming, but if you absolutely have to get the data, and there are no recent backups, this could be an option. I hope this is helpful, and hope you get to the bottom of it.
Try: Project Repair Kit. An absolute must-have for anyone willing to find out how to repair MS Project file contents with a few clicks and without leaving their workplace. This corrupt MS Project file repair software saves money and time by letting users restore their data on their own and forget about expensive specialized services.
For more information: http://www.project.repair/
As it works you will find here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/project/474-i-have-a-microsoft-project-file-and-it-won-t-open
SOURCE: How to view corrupted mpp file of microsoft project ?
We have to discover what is failing: the export or the import part of the process.
There are several open source programs to check if a XML file is valid. If the XML file is found to be invalid, you know there is a bug in the export process.
If you are not afraid of command line interfaces (this has future, also in MS environments), xmllint can be a good tool to validate XML.
MPP Viewer Tool - from http://www.mpp.viewertool.com/
SOURCE: Microsoft Project cannot open the file
1.Open the .mpp file in Microsoft Project 4.x.
2.On the File menu, click Save As.
3.In the File name box, type the file name that you want to save.
4.In the Save as type list, click MPX(4.0).
5.Click Save.
Files in MPX 4.0 format can be opened directly in either Microsoft Project 98 or in Microsoft Project 2000.
If you are still experiencing the issue you can try Project Fix Toolbox https://www.fixtoolbox.com/projectfix.html
SOURCE: MS Project 2010 - when
Guys need office 2010 key can go site www.vinhugo.com to got. My key go there and after i used is great works. Hope can help you.
