Watches Logo
Don Fallick Posted on Jul 05, 2018
How do I make my Sharp 100ft stop beeping every hour? I've tried all the online answers, and none apply.
Bought it at Walmart. None of the techniques online, such as pressing the reset button and holding it, while holding the mode switch do any of the things mentioned, and do not result in any opportunity to toggle the beep on and off.
5 Related Answers
Anonymous
  • Posted on Mar 10, 2008
SOURCE: How to set
in order to unset the military time on the watch you must hold down the two top buttons until the the 12 hour format comes back. in order to turn off the alarm you must hold down the two right buttons until they beep..and then the alarm will go off
Anonymous
  • Posted on May 23, 2009
SOURCE: Can't shut off beep going off every hour
Hold down all four buttons to reset the watch. My time didn't reset but the beeping FINALLY stopped.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jul 31, 2009
SOURCE: my watch beeps every hour.
Yes, you can. Go to the settings mode, push the pushbutton till you see the small blinking icon. Repeat to push the button till the icon disappears.
Rate me, please.
Anonymous
  • Posted on Nov 25, 2009
SOURCE: Diesel DZ7076 beeps every hour
Press all the buttons at the same time. It's so annoying...
Anonymous
  • 2501 Answers
  • Posted on Mar 18, 2010
SOURCE: I have an Armitron 40/8125 watch. I try to set the
You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 • Watches
Wont stop beeping
OMG me too!! Just got the watch today and none of the features to stop/start or reset respond!!! It's crazy...
3helpful
2answers
Stop beeping hour?
According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
How do u change a wr 100ft watch?
Hi I bought this watch WR 100FT for my son and the alarm
keeps going off does anyone know how to make it stop going off ?
I have tried everything.
Thank you for your time.
Mar 07, 2012 • Watches
I just bought this watch Nautica A31504 and it does not seem that any of the chrono buttons work. Is it the watch that is defective, or am I doing something wrong. In the manual, it says that I can...
The watch has been displayed for long time. You have to replace new battery for the watch and then those functions will work again. Good luck! :)
I have an alarm chrono watch from walmart and it beeps every hour, even though I've turned the alarm setting off. How do I make it stop?
I so have the same problem. I have the same velcrow chrono watch from Walmart. I was going to set the date on it when I accidentally set the hourly chime. I annoys everyone, especially when it goes off every hour.
Oct 05, 2010 • Watches
2helpful
3answers
Need to set time on WalMart TGHK watch.
If its digital that makes it more difficult to give setting directions online. Need to know the exact model #. I would do a google search to try and find your watch and you might find a manual online. OR you could seek out a local watch repair business and they should be able to set it with no problems. Most Sears have a watch repair kiosk in their stores! I woudlnt take it back to Walmart because they are just sales people! They have limited watch knowledge!
Jan 09, 2010 • Watches
16helpful
Need instructions or a manual on how to stop beep mode on watch
To turn hourly beep on/off: Hold the RESET button (lower right) and press the MODE button (lower left). When the days of the week light up, the hourly beep is on; when the days of the week are off, the hourly beep is off.
To turn the alarm on/off: Hold the RESET button and press ST/STP (upper right). Alarm light will go on/off.
Mar 26, 2009 • Watches
Top Sharp Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sharp Watch Expert? Answer questions, earn points and help others
